Open viewer pane when entering designated folders
Would you consider doing this for me? With your experience, I would think it a small matter of a couple of minutes for you to write the code I need to add to the script to make it complete. What say you?
Not on a Sunday night. Maybe during the week, time permitting.
Thank you!
Probably something wrong with it since I don't do VBS.
Option Explicit
Function OnInit(initData)
	initData.name = "AutoPane"
	initData.version = "1.0"
	initData.desc = "Automatically turn on Viewer Pane when entering configured folders"
	initData.copyright = "Based on Flat-View Auto by Leo Davidson"
	initData.default_enable = true
	Dim vecDefFolders
	Set vecDefFolders = DOpus.Create.Vector
	' Default folders / example config.
	vecDefFolders.push_back("C:\")
	initData.config.PaneOnCommand = "Set VIEWPANE=On"
    initData.config.PaneOffCommand = "Set VIEWPANE=Off"
	initData.config.ViewPaneFolders = vecDefFolders
	initData.config_desc = DOpus.Create.Map("ViewPaneFolders", "Folders which trigger the command.")
End Function
' Helper Function
Function IsPathInVector(fsu, path, vecFolders)
	IsPathInVector = False
	' Resolve aliases, libraries, etc. to their real/absolute paths.
	path = fsu.Resolve(path)
	Dim testPath
	For Each testPath in vecFolders
		If (fsu.ComparePath(path, fsu.Resolve(testPath))) Then
			IsPathInVector = True
			Exit Function
		End If
	Next
End Function
Function OnAfterFolderChange(afterFolderChangeData)
	If (Not afterFolderChangeData.result) Then
		Exit Function ' Folder didn't change.
	End If
	' Un-comment to make qualifiers (e.g. Alt, Shift, Ctrl) temporarily disable the script.
	' If (afterFolderChangeData.qualifiers <> "none") Then
	'	Exit Function
	' End If
  Dim cmd
  Set cmd = DOpus.Create.Command
  cmd.SetSourceTab afterFolderChangeData.tab
  If (Not IsPathInVector(DOpus.FSUtil, afterFolderChangeData.tab.Path, Script.config.ViewPaneFolders)) Then
    cmd.RunCommand Script.config.PaneOffCommand
  Else
    cmd.RunCommand Script.config.PaneOnCommand
  End If
End Function
Function OnActivateTab(ActivateTabData)
  Dim cmd
  If (Not IsPathInVector(DOpus.FSUtil, ActivateTabData.new.path, Script.config.ViewPaneFolders)) Then
  Else
  End If
End Function
Outstanding!! A million times, Thank You!! It works flawlessly. And you even added the section for turning off the viewer if I switch tabs while the viewer is on. Just beautiful!
And now that I've examined what you did, I can see where I went wrong with all my attempts. I simply forgot about using the Else part of an 'If-Then' statement. And I was sooo close, too. LOL
I cannot say it enough, Thank You! This will make things much easier and quicker for me, and in addition, I have learned just a very small bit about coding.
And of course, Thanks goes out to Leo for the original script!
