Open with - choosing a not default
There is a possibility to a short cut to "open with" option, so I can open the file with a program that is not the default?
Yes, have a look here: Launch Options
Tku.
Please,
what command should I use in the Hotkeys to configure this correctly?
The program you want to launch.
It can depend on the program, but usually this will work:
"C:\Program Files\My Program\My Program.exe" {filepath}
That will also work with nothing selected, to launch the program without a file.
