Opening DOpus in a particular monitor
For some reason, closing applications on a certain monitor no longer makes them open on the same monitor (I have three monitors).
So, I create a shortcut and click Properties, and there is a tab for a multi-monitor program called UltraMon (you may know about it). I have set Firefox to open on a particular monitor, nad it works, but when I try with DOpus, it still always opens on my main monitor (not the one I want).
Is there any setting in Dopus that might prevent DOpus to open where UltraMon wants it to?
Grateful for tips.
Regards,
Hans L
If you're opening the Default Lister then you need to set Preferences - Listers - Options: Default Lister positioning to Always in the same position.
If you're opening a Layout then you need to turn off Preferences - Layouts: Open layout relative to the monitor the mouse is currently on for the layout in question.
Thank you very much, Leo.
Regards,
Hans L
