OPENINRIGHT doesn't work with Go DRIVEBUTTONS
Hi,
I have "Drive Button" for each (left and right) lister.
Left:
[quote]<?xml version="1.0"?>
Drive Buttons
Automatically adds a button for each of the drives in your system to the toolbar/menu
116
Go DRIVEBUTTONS=hideempty,multifunc,removable,cdrom,fixed,network OPENINLEFT
[/quote]
Right:
Drive Buttons
116
Go DRIVEBUTTONS=hideempty,multifunc,removable,cdrom,fixed,network OPENINRIGHT
[/quote]
When I try to use OPENINRIGHT with DRIVEBUTTONS it opens drives in left lister (like OPENINLEFT which works perfectly). Problem doesn't exits with defined paths like:
Data
#goup
Go C:\MyData OPENINRIGHT
[/quote]
Could you help me with this problem?
You need to remove the multifunc since that overrides OPENINRIGHT.
Multifunc tells Opus that a left-click should open the drive in the left and a right-click should open it in the right.
Also, if you want all drive types you don't have to specify them, you can just use this:
Go DRIVEBUTTONS=hideempty OPENINRIGHT
Thank you. Support for DOpus is as great (and fast) as DOpus is :smiley:
