Hi There
I am experimenting issuing sending these set internal commands from a Java script: set SHOWFILTERFILENAME regex: set SHOWFILTERFOLDERS regex: set CLEARFILTERS
So far so good.
Now I want to read in the existing show filter into my script.
Is this possible?
Cannot find an equivalent internal command...
Thanks @Jon
Have incorporated and my script is looking cool.
JS as well.
Is there a method by which these fields can be written to?
Or do I have to use an internal command?
Thanks again
Thanks to help here I have this script which greatly enhances my productivity.
Upon invocation the script pops up a text box showing the current contents of the Folder Options > Show Filters > Filenames field.
The text can be edited and upon clicking Ok that field AND the Folder Names field is updated.
The Use regular expression checkbox is always checked for both File names and Folder Names.
So you can edit the filter of the current lister quickly and efficiently with a keystroke or button.
// 2019-01-29 Close Current Layout
// Original post from Leo
// 2020-12-09 Edit for Filtering purposes
// 2020-12-09 Want to add OR feature. Not started at this point
// 2020-12-11 Prompts with text field prepopulated with existing filter
// Upon andit and Ok filter is adjusted accordingly
// File and folder show filters set the same
// RegEx file always set (i.e. checked) for both File and Folder show filter
function OnClick(clickData)
DOpus.ClearOutput
DOpus.Output ("000100 Start")
var Dlg_Return
var Str_Filter_ENTERED
var Str_Filter_Existing = clickData.func.sourcetab.format.show_files
var Bool_Filter_Existing_RegEx = clickData.func.sourcetab.format.show_files_regex
DOpus.Output ("001000 Str_Filter_Existing : TEST")
DOpus.Output ("001010 Str_Filter_Existing :" + clickData.func.sourcetab.format.show_files)
DOpus.Output ("001020 Str_Filter_Existing :" + Str_Filter_Existing)
var dlg = clickData.func.Dlg; // creates a dialog object
// nothing happens until you invoke the Show() or getstring() method
dlg.getstring("Edit Show Filter:",Str_Filter_Existing,0,"OK|Cancel","Show Filter")
DOpus.Output ("001110 dlg.Input :" + dlg.Input)
if (dlg.Input == "undefined")
Str_Filter_ENTERED == ""
DOpus.Output ("002100a Str_Filter_ENTERED :" + Str_Filter_ENTERED + " set to empty string")
else
Str_Filter_ENTERED = dlg.Input
DOpus.Output ("002150b Str_Filter_ENTERED :" + Str_Filter_ENTERED + " set to dlg.Input")
DOpus.Output ("002000 Str_Filter_ENTERED entered :" + Str_Filter_ENTERED)
var cmd = DOpus.Create.Command()
cmd.RunCommand("set SHOWFILTERFILENAME regex:" + Str_Filter_ENTERED)
cmd.RunCommand("set SHOWFILTERFOLDERS regex:" + Str_Filter_ENTERED)
So far so good.
One thing that is not working is the attempt to handle the error whereby the text field in the popup text box is set to blank. I want this to have the effect of removing any existing filter. dlg.Input returns "undefined" according to my DOpus.Output debugs.
But the test for this does not work.
The return value is the entered string, or an empty value if the dialog was cancelled
However it seems to return the string "undefined"
Below is a debug output for the following sequence
Both file and folder show filters are blank for the current lister.
Script is executed
Popup with empty text field apprears (As expected as there is no filter text set)
Click ok without entering any text.
All files and folders disappear from the lister
Inspecting the Folder Options > Show Filters > Filenames/Foldernames filed show they are now populated with the string "undefined"
This is consistent with the debug output below.
This if statement is deemed to be (unexpectedly) false if (dlg.Input == "undefined")
In the test I am expecting the if statement above to be deemed true and then to see the following 2 lines of code executed
DOpus.Output ("002100a Str_Filter_ENTERED :" + Str_Filter_ENTERED + " set to empty string")|
But this never happens as the if statement does not evaluate the condition as I am expecting.
000100 Start
001110 dlg.Input :undefined
002150b Str_Filter_ENTERED :undefined set to dlg.Input
002000 Str_Filter_ENTERED entered :undefined
Thanks @lxp apologies for delay you know the muddle of life etc
I have run your script and it works of course perfectly failing to incorporate it into mine yet as I cannot for the life of me decode the line above.
Would you mind explaining?
I can see what it does when I run it and I need to drop the "regex:" string addition as that is build into my cmd.RunCommand differently.
I have worked out that (typeof dlg.input == 'string') is an evaluator of whether dlg.input comtains a string of not but that is about all.
In particular what is the function of the question mark ? ?
My thanks again to Leo and LXP.
This script will bring up the current contents of Folder Option >> Show Filters >> File names
field for editing.
Upon entering Ok the field (edited, unchanged or deleted i.e. so it is blank) will be applied.
The Regex checkbox is always marked.
The Folder names field is always set to whatever the File names field is set to. Regex checkbox for Folder names is also always set.
DOpus.ClearOutput
var Dlg_Return
DOpus.Output ("001010 clickData.func....show_files :" + clickData.func.sourcetab.format.show_files)
if (dlg.Result == 0)
DOpus.Output ("002000a dlg.Result :" + dlg.Result)
else
DOpus.Output ("002000b dlg.Result :" + dlg.Result)
// Str_Filter_ENTERED = dlg.Input
// Str_Filter_ENTERED = (typeof dlg.input == 'string') ? 'regex:' + dlg.input : '';
Str_Filter_ENTERED = (typeof dlg.input == 'string') ? dlg.input : '';
