Opus 13. double click column divider
Hi
usually this enlarged the column to fit the name but not anymore. Where can i set such setting ? see screenshot
last beta - works fine
Which width/mode are the columns set to? E.g Auto, Expand, etc.
In older versions, some modes would block manual resizing, although that shouldn’t be the case with Opus 13 and above.
Hi
I used fixed mode.or auto. Same problem
Can you show us the column list?
Like this:
sure :slight_smile:
The Max = Fill will limit how wide the column will go when double-clicked. Clearing that will let it go as wide as is needed to fit the content.
thanks :slight_smile:
