Opus and MSN Deskbar
If the "Replace Explorer for all file system folders" is checked in Opus the MSN Deskbar stops working with a Windows Explorer error: "The path 'Desktop Search: samplesearch' does not exist or is not a directory" whenever you try to view the search results. Any workarounds?
If you change the option to "Replace Explorer for all but the following folders" and then click Add, can you find the Desktop Search directory in the tree?
If so adding it to the list should fix the problem. If not I'm not sure what to do and it might be worth reporting it as an issue via the GPSoft site so it can be investigated and worked around.
Thanks for the report, this will be fixed in the next version.
