Opus as Audio Player
Is the volume bar slider in audio player linear or logarithmic? I find it hard to manipulate to silence it down to acceptable level as I'm running out of pixels. Should be logarithmic, but now I'm not so sure. :slight_smile:
Also, is there a way to minimize Viewer pane and let it play music in the background. Maybe it'd be too much to ask from a file manager, so just asking. I'm thinking of a way to put some nice chilling, 2-hour background music while working.
2024-02-09_102807
I don't think there is. You could use
Play QUIET
instead.
I think it’s logarithmic, from memory of having to do the conversion for one of the video APIs so its volume levels worked like the other two.
