Opus Cfg => move/copy/merge
Hi folks,
Opus is a world-class product, kudos folks ! :thumbsup:
However, it seems to me that it is missing out on a significant opportunity to add value
and hugely boost its revenue stream.
My colleagues and I often I work on different sites for the same customer,
and as we gather information and store it in collections,
it would be useful to be able to exchange collections of files that we've gathered.
Also, as we tweak Opus to make features available, we can't easily
give the tweaks to others.
... these would both mean copy, move or merge
I would imagine that Opus could get many more sales if it made this process available, powerful & easy
(which would require careful design and some beta-testing partners, hello, volunteering ! :smiley: :smiley: :smiley: )
Simple things, like, a new employee joins a company,
so they receive an email with a link to a lan folder that contains collections of information
they will need, so that the set can be centrally managed,
and they could even subscribe to updates once GPSoft offers that feature.
What do you think folks ?
Many thx,
Cheers
Brian
You can use Settings > Backup & Restore to backup or restore entire configurations.
Individual collections can be imported and exported via the DOpusRT.exe command.
Other configuration data can be shared individually as well, although the exact/best way depends on which data you might want to share, if you don't want to restore an entire config.
