Hi, all of the sudden I opened Dopus today and I get a totally empty window without any toolbars, etc.
I managed to show everything up but when I open a new lister from the app, the window is still blank.
How do I reset the settings to the defaul as they came when I first installed the app?
Thanks
Uninstall and then reinstall will do that.
It sounds like one of the settings files was corrupted. That could happen if the process is killed or you lose power at the wrong moment, while the file is being saved, as one example.
Thanks for this. I reinstalled it and all works as before.
