Trying to export a script which uses an include script, I noticed a behaviour that seems to have changed.
Use case involves:
- An include script:
inc_<Name of the include script>
- A script using the above include script:
<Name of the using script>
It looks like:
- If
sorts alphabetically after<Name of the using script>
: then the proposed name during script share is<Name of the using script>
- But, if they are sorted the other way, then the proposed name in the file save dialog is
This seems to have changed, since I already shared a script properly (with its own name) and now it gets the name of the include script by default in the save dialog.
I don't think it's that big a deal since installing will copy both scripts to the proper folder, but it's a bit confusing to try and share script B and getting proposed to name the export inc_Script A.opusscriptinstall
EDIT: correction: the sort order includes the "inc_" part of the include script.
So if you export a script (using inc_whatever): the save dialog will propose the name of the script if its name starts with [A-H]
or I[A-M]
, etc ... ; otherwise, the proposed name will be the one of the include script.
