Is it possible to place the output window in the same place as the find/syncronize/duplicate/ panel at the bottom of dopus? Or maybe add it as another tab at the end next to the duplicate tab?
What is the second FTP#2 tab for in the Output window? I have FTP logging turned on and the output gets written to the FTP#1 tab and nothing ever seems to get written to the second tab.
You can only see the FTP logs via the output window; can't dock them with listers. I think they're intended to be for investigating FTP problems rather than something that you see all the time (though I know some people like to see FTP logs all the time).
If you edit an FTP site in the FTP Site List, on the Display tab, under Log, there's an option to send the log to channel 1 or channel 2. That's what defines which tab of the output window a particular site logs to. (You'd probably only want to set something to the second log if you were diagnosing a problem with site-to-site FTP. Even then, having both logs mixed together is often better.)
Oh yeah I see the option now to direct the logs to the relevant tab.
With regard to docking the output window it wasn't so much to see the ftp logs (but that would be nice when connecting to a site) it was for seeing the undo tab, email tab etc. When I want to use those areas it would be nice to have the option of docking the window at the bottom like the find panel. That way it can be toggled on & off and will always come up in the same place.
