Padding for Expandable Folders Arrow
I believe it would be beneficial to add a padding option for the expandable folders arrow. The use case is to grow the distance between the arrow itself and the folder icon/text to avoid mis-clicking either the arrow or the folder.
Support++
Yes, and perhaps that padding should be clickable to increase the arrow's target hover & click zone so it's easier to click.
