When viewing a ZIP or RAR folder in DO, the lister opens in "Power" View Mode. I would like to always open ZIP and RAR files in "Details" View Mode. Currently, I have to manually change this setting each time I open compressed files. What settings do I need to change to fix this?
You may just need to turn off the Zip format under Preferences / Folders / Folder Formats, under Folder Type Formats.
It would not be Power Mode but default so this should be undoing a change which was made previously. There are other things which may have be done to cause the same result, e.g. a wildcard path format on *.(zip|rar) or similar. But it's most likely the standard Zip format is turned on and set to Power Mode.
