In Picasa, Googles photo-indexing software, you can go to the actual file by right-clicking on a thumbnail and selecting 'locate on disc'. But I find that Picasa always opens the folder in Explorer, not in DOpus.
Since I've got DOpus set to 'Replace Explorer for all Folders', I was expecting that the folder would open in DOpus. Can anyone suggest how I can make this happen?
(Picasa version 2.7.0, DOpus ver 9.1.0.1.2947.x86, XP Pro).
You will probably have to talk to Google to ask them to change/fix the way Picassa launches folders.
Picassa is probably calling ShellExecute on the folder and specifying the "open" verb when it should, if its aim is to simulate a double-click on the folder, be passing NULL for the verb to allow the default to be used.
