Hello all.
I did search and I found a number of threads related to the size of the viewer pane itself, along with posts about scaling vs. reducing image sizes, but I didn't see any in the last year addressing inconsistent image sizing in the viewer.
Whenever I double-click on an image in DOpus and it opens in the viewer, the image is at its original size, which is usually very large. All I can usually see is a tiny piece of the image looking very large. I always have the viewer image size setting configured as follows:
Settings>Preferences>Viewer>Standalone Viewer>Auto-size viewer window: To fit every picture
Occasionally that works for a very short time, but it always seems to jump back to showing images at their original size. Not a terribly big deal since I just have to use the zoom button to bring it down to a viewable size, but it is pretty annoying.
Is there any other dependent setting that is required to be configured a certain way in order to make this viewer image size setting work? Is this happening to other users also? If need be I can post screen captures of my Preferences dialogs so someone can point out if any other setting is causing this.
Thanks for any advice!
Jim
