Pin a Folder
Is there a way that I can PIN a folder in DO? I have several folders that I use frequently. If I could pin them, and then when I navigate within those folders, they would open in new folders. That way, I could always have a set group of folders I can get to quickly.
Do you mean tabs?
Have you tried tab groups?
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Tab_Groups1.htm
Locked tabs may also be what you're looking for. See the bottom of https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Tabs.htm
You can also have toolbar buttons which take you to your most used folders, of course.
