Greetings,
Which where "Pin Buttons" are hid under v10:?: I cannot found them.
Regards
Greetings,
Regards
Same place the separate Find window went.
Thanks to answer, but are you sure DOpus 10 is an upgrade?
That's how I'd describe the removal of antiquated features that don't work properly on modern operating systems, yes.
The pin buttons have never been available on Vista or above, even in Opus 9.
You can still make windows on-top via the system menu (see the FAQ on on-top windows).
Also have a look here: Title bar in DOpus 10
[quote="leo"]The pin buttons have never been available on Vista or above, even in Opus 9.
You can still make windows on-top via the system menu (see the FAQ on on-top windows).[/quote]
I have not changed my OS My OS is the same as previous, Win XP, but the pin is missed under v10.
Thank you very much. That worked great
