Please implement easy MRU cleaning.
In the name matching field all names gets saved and i have to manually clean them out all the time from the State Data/MRU directory.
You could make a button which deletes the files and restarts Opus. Would that solve it?
Yes it seems to work even without restarting dopus.
I just delete all 9 files in the MRU folder with a * wildcard in a button works great =)
What is an MRU folder ?!.. o)
MRU = Most Recently Used. It's the history of things you have used recently so you can select them again. For example, recent paths or find filter strings.
Ah, I see.. did not know the abbreviation.. o) Thank You!
