Appear to be having an issue with column alignment (see screenshots) - both of these tabs have the SAME folder format applied ? But the first screenshot show an offset if you look at the ext, Type and Date columns.
Any ideas would be appreciated (i.e. if I'm doing something weird of if there is a problem with DOpus ?).
Thanks
Phat
Below - Correct Alignment (but there appears to be an additional column header linked to the 'Name' column that just displays the sorting arrow ?
The thing on the left of the second screenshot is normal. It should appear when you are sorting by more than one column and it's purpose is to let you reverse the multi-column sort order.
In the first screenshot it looks like the file list itself has adjusted for this thing but the list header has not (or hasn't been repainted). Can you work out how to reproduce the problem in the first screenshot?
Both Folder formats are based on a custom format - 'Normal', the default format (set for Local Drives, Removable Drives etc) are also set to 'Normal'.
When I open a folder Group (or when DOpus opens), all the tabs appear with the first column layout (with the annoying offset), if I then change one of the Folder formats to some other format and then back to 'Normal' it seems to correct itself and shows as the second folder format (which if the extra sort column is supposed to be there is correct).
Have even tried setting up all the Folder tabs to display correctly and then saving over the Folder group, but the next time DOpus opens the problem returns.
I've been able to reproduce this - seems to be caused by having multiple sort fields defined for a tab in a tab group. We'll get it fixed for the next version!
