I was looking for suggestions on how to convert a rename script/preset into a possible standalone solution for other users to deploy?
I find that DOPUS has the best rename capabilities and I wanted to package a preset I commonly use for other users to apply. It could be a windows exe or a script file that can run under normal windows?
I see that we are halfway there with the script function one can write. Then all that is needed is the file management aspect as the parent script that can execute it.
Or better yet, deploy DOPUS Rename as a standalone free tool. (but that would shift focus energy away).
