Hello there.
I'm struggling a bit with Print / Export folder Listing.
I want to export a filelist to CSV, but I don't quite know which fields to use
I want (a) the full file path without the file name, and (b) the Filename. The latter is easy, but how do I get (a)?
"Parent Folder" only gives the name of the folder that contains the file.
"Parent Folder (Full) " gives the name of the folder that contains the file, followed by the path in brackets.
"Full Path" gives the full directory path plus the file name.
Is there any way to get the full directory path on its own, in the order it is on the computer?
I'm sure I have manged this before, but I can no longer find how to do it.
Secondly, is there somewhere that I can find the definitions of all the fields one can chose from in the "Columns and Grouping" box to export? It5 must be in Help somewhere, but has eluded me.
Please could someone point me to the right place.
Thanks in advance
Guern
