Print folder contents : I want to print specific subfolders
Hello opus community! I need your help!
I have a folder that contains several subfolders that contain their own subfolders etc. I want to print only the contents of the folders that their parent folder is named "Photo". There are several folders with that name located in different locations.
I appreciate any help!
You could gather these folders with Find and run Print on them. Here's a filter that should work:
Save photoparent.ofi.txt (remove .txt) to
%appdata%\GPSoftware\Directory Opus\Filters
This was exactly what I needed. Thank you so much!!
