I just installed the trial version of DOpus and noticed that I cannot see all items in the shell menu because I just cannot move to the items at the bottom of the list like Send to, Rename, Properties etc. which are quite important of course.
I used Total Commander so far and there are arrows when looking at the shell menu so I can move up and down to entries but no arrows when right-clicking on a file in DOpus and no chance to scroll down neither by mouse nor arrow keys, can this really be true or what can I make to change this ? More than 20 entries in the shell menu here (and not the smallest Windows fonts installed because my eyes are not very good) but a file manager should be able to move to all entries in the shell menu or not ?
Thanks for replying, I think that the problem is solved see the attached screenshot.
The line at the bottom is divided into a left and right panel (nearly invisible but..) and by clicking on the left side you get the items in the shell menu above and by clicking on the right side you get the things below (important because of "Rename", "Delete" etc), new to me this way but acceptable, of course.
Yes, the arrows at the bottom there were difficult to see when not using Visual Styles. That will be fixed in the next version (in your screenshot, the arrows will be black instead of white).
