Problems with display text
I've started using this great piece of software (trial version with 60 days...Almost up), and I'd like to buy it when my time expires, however it does something INCREDIBLY annoying and essentially makes the damn thing unusable: Randomly the application decides to shorten and capitalize all of the files and folders name's in it's window panels.
Example: The folder "Mike Yonkers" becomes "MIKEYO~1". The file "01 Goodbye Sunball.mp3" becomes "01GOOD~1.MP3"
This is very confusing and frustrating, as I don't see ANY options to turn the feature on or off. The only way I've found to get around it is reinstall the app completely.
I haven't installed any updates or used a cracked version.
I can't buy this if it keeps shooting itself in the foot out of the blue.
Any help?
Best thing is to re-download the latest version (9.0.0.6) and reinstall - it sounds like something has corrupted your installation.
