Commentary: I've been using DOpus for many years. While I don't make it Windows' default "explorer", I use it regularly and value its power & versatility greatly. Keep up the good work.
Does (or can) the "Convert Image..." function-set accessible from the context menu (in the context of a Lister window when the mouse pointer is floating over an image file) support and use acceleration via a Window's system's discrete graphics -- e.g., popular NVIDIA graphics card(s) -- if the system has such graphics properly installed? If that DOpus function-set currently can support use of such discrete graphics, what if any DOpus-side settings must be changed for such support to be activated? If not, I suggest GPSoft (or any graphics engine developer GPSoft partners w/for this function) consider adding such support into a future build. While the "Convert Image..." function-set is intentionally and appropriately limited, its accessibility from w/in DOpus is a boon, and users like me could still benefit from substantially greater conversion speed if use of discrete graphics is currently unsupported but could provide that additional speed if supported.
Thx,
Mike
P.S. I'm currently running DOpus on a Samsung Model NP500P4C-S02US laptop running Windows 8.1 Pro w/Media Center. The laptop contains a Core i5-3210M CPU w/Intel HD Graphics 4000, Ivy Bridge Chipset 8 GB of installed physical RAM, and an NVIDIA GT GeForce 630M dedicated graphics. I have GeForce drivers installed, with associated NVIDIA Control Panel & System Tray GPU Activity Icon activated. I see no evidence in the icon's appearance and associated tooltip text that DOpus is using the GPU either generally or during a "Convert Image..." function-set task I frequently perform ("Rotate"). Furthermore, within the program-specific settings available from within NVIDIA Control Panel, I see a long list of programs in the applicable drop-down list -- a subset of all applications I have installed on the system -- but no evidence of DOpus within that list. (Corresponding default setting for graphics hardware is "Auto-select" via NVIDIA Optimus Technology.)
