Progress Indicator
OK, hi all, hopefully there is a fix for this problem I have
Opus is by far the most used program on my system, It's my go to for just about everything
Having said that there is 2 things that piss me off big time
  1. That bloody progress indicator, every time it opens it's right in the middle of the damned screen and I have to move it out of the way, every single time, stupid, why can't I define it's opening position ??
  2. The copy queue, every time I use it I have to tick the box that says "don't show comfirmation for this queue"
    I tick the box and it comes up again, another bloody annoying thing
  3. this ones not a winge, those are the only things that annoy me, other than that all is good, well actually great :slight_smile:
So I'm running 10.5.7.0 64 bit version
Please let there be a fix for these things !! hopfully someone can enlighten me how to do these things
Cheers
BMSteve
  1. In Opus 11 or 12, you could turn on Preferences / File Operations / Progress Indicators / Minimize progress indicators (and probably would want to turn on Display the jobs bar automatically when starting a new job as well, so the progress is shown at the bottom of the window instead of in a separate window).
  2. Turn off Preferences / File Operations / Copy Options / Display confirmation when a job is queued.
Thanks Leo
I looked all over for that option Q2, just couldn't find it
I had a play around with 12 a while back, it's nice, may buy it for myself for christmas
Thanks a lot, one of my winges fixed :slight_smile:
