I am an evaluation user but cannot submit a bug/issue to Opus via the email page (says expired, but I registered 16 days ago?), so I thought I'd post it here.
When displaying 'protected' WMA music files (e.g. Napster tracks) in Opus 9 (9.1.0.6.3044.x86, Windows XP SP2) the track number is incremented by 1. So the first track is 2, the second 3, and so on. For unprotected music files the display is OK.
It occurs in the Lister and the Info Tip.
Could this be fixed please?
Napster and Windows Media Player display the track numbers correctly (start at 1, ... up to the last track of the album). Also, just checked Windows Explorer, and that displays correct track number.
In Opus Lister and Info Tip the track numbers are +1 (start at 2, ... up to the last track of the album). Interestingly I checked the Properties Dialog in Opus as you suggested, and the track numbers are correct?
Although this looks like the standard Windows XP Explorer Properties Dialog to me?
In Opus, I sort my display by track number for (File Type Group) Music files.
This only affects protected WMA tracks I download from Napster; but since I have a lot of these and I am syncing to other folders it's a nuisance.
This turned out to be Napster incorrectly tagging the files but a workaround should be included in the next Opus release.
WMA tags can indicate the track number in two different ways. Napster's files have both types of track number tags and one of them is +1 from what it should be. (The tag is documented as zero-based; Napster are writing it as if it was one-based.) Opus happens to look for that tag first while most other programs seem to look for the other tag first.
