Queued "copy out of zip" does not respect unattended mode setting
  1. copy something from source drive to destination drive
  2. while copy process is underway, go into a zip file in source drive and copy files out of the zip to destination using copy button, at least one of the files has to already exist in destination to create a conflict later.
  3. action nr. 2 is added to the copy queue automatically. Open the queue, check unattended operation, select "replace" as the resolve action.
-> even though unattended operation is set, and replace is set, I still get a modal replace requester when the zip extraction tries to extract the file that already exists in destination.
The correct behaviour would be to adhere to the unattended operation default, and overwrite the file.
Thanks, this will be fixed in the next update.
