Dear friends,
I need your help once again!
I currently use the following command
Copy ARCHIVE=.rar CREATEFOLDER="{file$|noext} - {date|yyyy-MM-dd} {time|HH-mm-ss}" HERE
to create a backup of a folder with a timestamp.This command is on the file types context menu.
I would like to add one more step and log the backup timestamp into a filename called "backup.txt" inside the folder.
I understood that I have to mix command with script and then I stacked!
Also I would like to ask if there is a compression level parameter for rar files. I noticed that my backups are quite big compared with best compression result directly with rar.
Any ideas / suggestions are more than welcome as always.
Wow!!!!
This is exactly what I would like to do!
I didn't know the MS-DOS Batch Function.
This program always amazes me!
There are so many cool cool features!!!
Thank you!
DOS Batch isn't something I'd recommend often these days. You're usually better off using JScript or VBscript. But if you only need to append something simple to a text file, that's one of the few things where DOS Batch is a bit easier than the scripting route (as long as you don't care about unicode, etc., which DOS Batch is not good for).
