I want to create a column on a large collection (~1850 folders) that has the rating (stars) for that folder. My question is i don't want the rating to disappear if i ever decide to relocate the folder.
Is there a file inside of the /dopusdata that has the ratings in it that I can modify if needed?
They're stored in an ADS datastream for the folder. As long as you keep the folder on an NTFS-formatted drive it shouldn't ever disappear (make sure you have the option in Opus to preserve metadata when copying turned on).
The data is stored as binary so you can't easy edit in a text editor.
They should copy with Explorer as far as I know. If an app does a "safe save", by writing out a new file, and renaming the old one, then the metadata will probably be lost unless the app takes steps to preserve it.
