after upgrading to 12.3 I am constantly asked to reboot.
I have rebooted many times but am still asked to reboot - what should I do?
Open RegEdit.exe and go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager in the tree on the left.
Is there a PendingFileRenameOperations value on the right? If so, double-click it. Does it reference any of the Opus program files?
If it is there, and still there after a reboot, it may mean something is messed up with the Windows install, since the listed operations should be carried out when the reboot happens, after which the PendingFileRenameOperations value is deleted.
Are there entries in there for other things as well as Opus?
contains the following :
??\C:\Program Files\GPSoftware\Directory Opus\Language\engl3960.rra
!??\C:\Program Files\GPSoftware\Directory Opus\Language\english.dll
??\C:\Program Files\GPSoftware\Directory Opus\dopu3b25.rra
!??\C:\Program Files\GPSoftware\Directory Opus\dopusbch.dll
??\C:\Program Files\GPSoftware\Directory Opus\dopubff5.rra
!??\C:\Program Files\GPSoftware\Directory Opus\dopus.exe
??\C:\Program Files\GPSoftware\Directory Opus\dopuc786.rra
!??\C:\Program Files\GPSoftware\Directory Opus\dopushlp.dll
??\C:\Program Files\GPSoftware\Directory Opus\dopucd62.rra
!??\C:\Program Files\GPSoftware\Directory Opus\dopuslib.dll
??\C:\Program Files\GPSoftware\Directory Opus\dopud08f.rra
!??\C:\Program Files\GPSoftware\Directory Opus\dopuslib32.dll
??\C:\Program Files\GPSoftware\Directory Opus\Language\engld5bb.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopud5fa.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopud8e8.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopud945.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopud984.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopud993.rra
??\C:\Program Files\GPSoftware\Directory Opus\VFSPlugins\opusd9f1.rra
!??\C:\Program Files\GPSoftware\Directory Opus\VFSPlugins\opus7zip.dll
??\C:\Program Files\GPSoftware\Directory Opus\Viewers\gifadadd.rra
!??\C:\Program Files\GPSoftware\Directory Opus\Viewers\gifanim.dll
??\C:\Program Files\GPSoftware\Directory Opus\Viewers\movidb69.rra
!??\C:\Program Files\GPSoftware\Directory Opus\Viewers\movie.dll
??\C:\Program Files\GPSoftware\Directory Opus\Viewers\targdbe5.rra
!??\C:\Program Files\GPSoftware\Directory Opus\Viewers\targa.dll
??\C:\Program Files\GPSoftware\Directory Opus\Viewers\textdc04.rra
!??\C:\Program Files\GPSoftware\Directory Opus\Viewers\text.dll
??\C:\Program Files\GPSoftware\Directory Opus\Viewers\textdc14.rra
!??\C:\Program Files\GPSoftware\Directory Opus\Viewers\textthumb.dll
??\C:\Program Files\GPSoftware\Directory Opus\Viewers\wmaddba.rra
!??\C:\Program Files\GPSoftware\Directory Opus\Viewers\wma.dll
??\C:\WINDOWS\TEMP\SKY9772.tmp
??\C:\Program Files\GPSoftware\Directory Opus\Language\engl6c02.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopu6ff9.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopud0b7.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopuda2d.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopudcfb.rra
??\C:\Program Files\GPSoftware\Directory Opus\dopuddc7.rra
??\C:\Program Files (x86)\Google\Chrome\Temp\scoped_dir_6252_15267\old_chrome.exe
??\C:\Program Files (x86)\Google\Update\1.3.31.5
If you check it right after rebooting, is it the same?
