I use the "Path" option with the "Recent" command on my drive buttons to create a recent list particular to each drive. This worked in V8, but in V9 I'm getting an 'unfiltered' recent list (showing paths from all drives).
FOR instance, using "Recent Path D:" produces:
F:\CD Images
M :\video
M :\Musc
D:\My Documents\oneNote Notebooks
D:\Photos
C:\Documents and Settings\owner
These are just some ideas I'm spewing out here:[ol][li] Is D:\ by any chance a removable or network drive (i.e. something that my be re-assigned a different letter form time-to-time?
[/li]
[li] Backup your config. Uninstall Opus (completely). Re-install it stock, and import my button. Does it work?
[/li]
[li] If the above works, try re-importing your config. Then import my button. Does it work?[/li][/ol]If none of this works, submit an official request (see link in my signature). In the request, paste a link to this thread (right-click the anchor link in your first post and select Copy Shortcut).
