Recreate Empty Directory Structure
I need something very similar to this. I'm not a coder at all, so please be gentle. :wink:
I have an example folder structure that will always be the source. It's the Case Folder Template in the attached screenshot.. I need a button that prompt me for a case name, then copy the Case Folder Template folders, recursively, to the currently selected pane with the top-level folder being the name I entered in the prompt..
Any guidance on this would be much appreciated.
2023-04-03_03-09-46
Try
Copy FILE="F:\Case Folder Template" TO={sourcepath} CREATEFOLDER="{dlgstring|Enter case name}"
Huge thanks. It's almost there. As you can see in the screenshot, it copied the Case Folder Template into the new case folder (TestOMatic). What I'm looking for is a new folder called TestOMatic in the root that has exactly the same folder structure as Case Folder Template.
Again, thanks!
Change FILE="F:\Case Folder Template"
to FILE="F:\Case Folder Template\*"
Perfect! A million thanks!
Thanks! This is great, I was looking for the recursive version :smiley:
