Recycle Bin Bypass
Just started using Opus..... nice!
Question though:
How can I 'shift-delete' bypass the recycle bin?
Performing same, puts files/folders into the
bin. I have gone into Preferences and attempted
to force the bypass to no avail.
My system used to have the abilty to bypass
using the shift key.
Ideas appreciated,
-Miles
To delete to the recycle bin by default, but allow shift to override it, your delete toolbar button should run this command:
Delete SHIFT FROMFOCUS
You can also completely disable use of the recyclebin in Opus if you like (i.e. without having to hold shift) by changing the command to:
Delete NORECYCLE
Or you could turn off Preferences, File Operations, Deleting, Delete using the Windows Recycle Bin if possible.
