Recycle bin not working in libraries (DOPUS 10)
I just upgraded to Dopus 10 [10.0.0.0.4137 x64] today - very exciting.
However I did notice an odd behavior that I can not seem to correct using application preferences so I wonder if it is a bug.
Deleting files from within a "library" (using Win7) prompts me with a pop-up "Really delete the file 'desktop.ini'?"
Deleting files from C:\User\Me\Documents prompts me with a pop-up "Really send the file 'desktop.ini' to the Recycle Bin?"
Note that it is the same file in my own document folder but it behaves differently depending on how I navigate to it. Windows Explorer prompts for Recycle Bin both ways.
That does seem wrong. I've put in a bug report.
