Redirect to Output Window
Hi,
is it possible to redirect the output for an external command to the output window? I would like to redirect commands like "dir c:" as a sample...
Is that possible?
Thanks
Not sure, but for the example you gave about doing a 'DIR' on a folder or drive I think you could accomplish the same thing by just doing a find/search for . and select Output Window for the Show results in: drop down. But I'd imagine you've got other external commands you might like to re-direct like this eh?
Yes correct, it was a bad example. I would like to redirect other external commands to the output window.
As far as I know there's no way to do this. The Output Windows is only used by certain Opus things. (In fact I haven't viewed mine in months. :slight_smile:)
(Moved to Feature Requests)
