Directory Opus 13.23.1 (Beta):
You can now undo restoring items from the recycle bin (i.e. if you delete a file to the recycle bin, then undo it, you can now redo the delete).
The redo-menu is blank when redoing recycle bin operations. It still works as intended, but doesn't show what the operation will (re)do.
In this example I did this:
- Deleted
Clipboard Text (2).txtandClipboard Text (3).txt - Undid the delete of
Undo items show up correctly, but the redo item is blank (but still works):
(The menu is Undo LIST=both which I think is default.)
EDIT: While I quoted 13.23.1, this was tested on latest beta (13.23.6) ![]()
