When I click back onto a DO tab that I haven't been on for a few minutes the file path for that tab will revert back to "File Collections". I have recently updated to Windows10 from WIndow 7. Anyone know what might be going on?
Thanks
It sounds like the tab might be locked, see the bottom of the page at https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Tabs.htm for details.
Thanks Jon. Definitely not locked. I have multi tabs open at any one time and it's happening across a number of tabs but not consistently.
Do you have any script add-ins installed? (Preferences / Toolbars / Scripts)
No scripts at all.
Does reversing the Preferences / Folder Tabs / Options / Process file changes in background tabs setting you have currently make any difference?
