Regarding the vector problem, is this a bug?
code
result = "test"
set v1 = dopus.create.Vector(1,2,3)
set v2 = dopus.create.Vector(4,5,6)
for each v in v1
	result = v & vbnewline & result & vbnewline
next
dopus.output "=========="
dopus.output result
output
3
2
1
test
Shouldn't the result be like this?
1
test
2
test
3
test
No, that's a bug in your code, not ours. :slight_smile:
Can you help me point out where the error is?
start: result = "test"
v = 1: result = "1" + result = "1 test"
v = 2: result = "2" + result = "2 1 test"
v = 3: result = "3" + result = "3 2 1 test"
This would produce the desired output
result = "test"
for each v in v1
	dopus.output v & vbnewline & result & vbnewline
next
End Function
