Folder Formats add wildcard path format
wildcard path: temp
not match
d:\Temp
d:\111\TEMP
c:\windows\tEmp
wildcard path: temp
not match
d:\Temp
d:\111\TEMP
c:\windows\tEmp
I don't think case sensitivity is the issue, it's just that the pattern doesn't match. "temp" won't match anything other than "temp". You'd need to use wildcards to make it match more, e.g. "*\temp" should match all of your examples.
