RegExp Help
Hi guys,
I need help with a regular expression that selects all text before the first hyphen in a bunch of filenames. My aim is to move the files into a New Folder with the Users Name, a sub-folder with the Project Name, another sub-folder with the file extension.
i.e.
Steve Dave Jones - Big Project - Useful Stuff.txt --> Steve Dave Jones\Big Project - Useful Stuff\txt\Steve Dave Jones - Big Project - Useful Stuff.txt
Dave Jones - Minor Project.dwg --> Dave Jones\Minor Project\dwg\Dave Jones - Minor Project.dwg
The filenames all follow one of four patterns, see below.
[ul][i]Steve Smith - Project Name - More Info 23.txt
Steve Smith - Project Name 23.txt
Steve Jon Smith - Project Name 12 - Data Sheets.dwg
Steve Jon Smith - Project Name.dwg[/i]
(Names have been changed to protect the innocent)[/ul]
The first block is always text. The second and third blocks can be a mixture of text and numbers.
The following Regular Expression works on the files with a single hyphen but those with two hyphens.
Old name: b - (.).(.)[/b]
New name: \1\\2\\3\\1 - \2.\3
Type: Regular Expression
I'm sure I've read about this on the forum someone before but I can't find anything now. hopefully I've explained everything well enough as well.
Any help would be much appreciated.
Regards
Blueroly
I'm in the same boat. I have a rename that needs to find the first "double space" as in " ".
I am getting there. As I understand, you need to anchor the first occurrence of " - ". And the whole search.
Drat. I wanted to go and get my examples, to show that it need a "?" somewhere in the string, but I fell over a crash that I reported last week and haven't had time to pursue.
You might like to search for the message with the search "Regex (everything after second " - ")
[quote]by playful
p.s.:
The last post was the "why".
For my taste, I would probably go for something like:
pattern: (?:.?\s-\s){2}(.)
Rename Regexp Pattern="[^-]-[^-]-(...)" to "\1"
[/quote]
Not what you are after, but maybe a few clues.
Search for the source of this snippet that I filed away.
But I suspect that one of those ever helpful regex jockeys will dive in with the answer you want. I just like to work it out for myself so that I understand what I am doing.
We're waiting for more info from you on that, BTW. Not sure if you saw my reply.
[quote="blueroly"]Hi guys,
[/quote]
This is better done with a substitution since your output requires adding additional components depending upon the captures (so simple pattern matching alone won't work).
Use this as a Rename script in Script mode. Just check Script mode, and paste the code below. Set Old Name/New Name both as *. Save it as a preset for later use.
@script jscript
function Rename::GetNewName2 ( strFileName, strFilePath, _fIsFolder, strOldName, strNewName )
return strFileName.replace(/.| - /g, "\") + "\" + strFileName;
[quote="michaelkenward"]I'm in the same boat. I have a rename that needs to find the first "double space" as in " ".
[/quote]
Is there a question in your post somewhere? If so, can you restate what you have / need?
Thanks Michael, Playful's post seems to do what I want. I just need need a bit of time to digest the information, so for now, I will ignore this post until I work out a solution. Is it sad that I'm getting quite hooked on this Reg Exp stuff?
MrC... your script works perfectly...thank you. I still want to go away and work out the RegExp though.
Thanks for all your input guys.
I'm tiring to do some very simple search's. But. The term RegExp got me interested in this post. I have a program I have not used called RegexBuddy. regexbuddy.com/ seems to offer a lot of help with RegEXCp. I might be way off. Just wanted to help if I can.
Bob
You're welcome.
And go check out the Perl substitutions script I just posted in the Rename forum.
We're waiting for more info from you on that, BTW. Not sure if you saw my reply.[/quote]
Apologies.
I did see the reply but have been too busy to pursue it.
Interesting use of the question mark there!
I know what you mean. "How does that work?" is an all too common question at my end. All too easy to get hooked on trying to work it out.
I am currently going through some of my old topics that I responded to. This is one I am going to spend some time with, I see a lot of value here. I just would like to pass on one thing that became apparent to me that I was not expecting. it's how they placement of the"" affects any filename.
Filenamee: 58blueford.jpg
By placing "" I end up creating folders.
Rename file name: 58\blue\ford
Result: Folder's
\58\blue\ford With a filename called (.jpg) within the folder called ford.
I found this to be very interesting and was not aware of this capability. I'm not sure if this capability comes from Opus or Windows all I know is that it works.
Bob
