Remember volume-level
When using DO's internal player for previewing audiofiles the volume is always set to defualt (50%) when switching to the next file.
Would be great if DO remembers last volume-level (like in WMP).
Do you mean in the preview pane rather than via double-click?
If so then that is WMP, via my ActiveX plugin. I've made a note to myself to see if I can get/set the WMP volume between files as it should be possible.
(The internal sound player doesn't have a volume control at all and isn't used by the preview pane. WMP in the preview pane always sets its volume to 50% for me as well, though.)
Yes, it's WMP. The plugin does not make use of the WMP's settings.
