Remove "_" and "." with rename preset
How to (I don't understand the regexp-thing!)?
Regular expression rename from
to
\1\3
Or, if you want to remove the . in the file extension as well, then change the from string to:
Thanks Leo, I really need to spend some time for this...
Just to say that leo's regexp replace . and - instead of _
So Sasa if you want to replace _ change to (.)(_|.)(..[^.]+)#
(_|.) mean search _ or .
You can replace others characters by adding characters separated by | in parenthesis.
