Removed OneDrive, finally removed it from Directory Opus
From NikolinoDE at techcommunity.microsoft.com
Disable OneDrive Integration
  1. Press Win + R: This will open the Run dialog.
  2. Type "gpedit.msc" and press Enter: This will open the Group Policy Editor.
  3. Navigate to "Computer Configuration" > "Administrative Templates" > "Windows Components" > "OneDrive".
  4. Find the policy called "Prevent the usage of OneDrive for file storage".
  5. Double-click on the policy to open its properties.
  6. Select "Enabled" to disable OneDrive integration.
  7. Click "Apply" and then "OK".
What I did
They were all marked as Not Configurred
I changed to
Then I copied my \johna\Documents to Favorites.
Now
It seems to have fixed it
