Rename help reqd
HI
Hope someone can help, i'm not a techie so please be gentle.
On doing a batch rename what i see on the preview doesnt match what the actual rename is
Screen 1 image shows the preview
screen 2 shows the actual filename after renaming
Heres hoping someone can help
Many thanks
Gordon
You can fix things by making it explicit where you want the number to appear, by adding [#] to the New Name field:
It should then do what you want.
It looks like this is a bug where renaming things in subfolders does not put the number before the extension if the placement is not explicit. We have some enhancements to the Rename dialog coming which will fix this, put using [#] will also fix things for you now.
Awesome Leo many thanks for speedy resolution, working fine now thanks again
Gordon
