Recently I reinstalled Directory Opus 13 on a new computer. After installing, I noticed that the combo box with rename modes is empty, so I can't choose "Find and replace" or "Regular expressions". I've tried removing and reinstalling, and I tried several versions, 13.4, 13.6 and 13.12, but the problem remains. Does anybody know how to fix this? Thanks....
Are you on an ARM machine?
Yes, I am. I'm running Windows 11 with Parallels on a Mac Mini M4. Before I used a MacBook Pro with intel...
It’s a problem with Windows ARM at the moment.
Ok, thanks...
