Rename panel: Ctrl or Shift Select
Unsure if this has been asked before - if so, I am sorry, vainly searched for it.
Rename panel -from a long list of files that I have displayed there - I wish to rename let's say 10 files this way, 10 files in a slightly other way .etc.
Right now I am unaware of any other way than a lot of tagging/untagging-clicks.
Will there be a way to ctrl-shift select files, similar to the normal panel?
Click the first check-box, then shift-click the last, and all the check-boxes in between will be toggled as well.
Sorry for the delay.
Many thanks indeed!
