I have thousans of PDF files that need to be renamed, and I would like to use the metadata to build the new name of the file. Alternately can I read the first line of text from the PDF?
Does anyone have any suggestions and/or sample to work from?
If you turn on Enable file information fields in the advanced Rename dialog then you can use the drop-down arrow that appears by the New Name field to select Document columns such as Title, Author and Keywords.
I just tried this in Opus 10, but it does not appear to work. The file I tried it on shows proper PDF metadata in Properties.
The New name box correctly shows: {author} - {title}.pdf
I have enabled file information fields.
Under New Name in the preview I just get " .pdf"
You are right: the PDF data do not appear in the Opus Metadata.
Fortunately most PDF's turn out to have proper metadata. Opus is a real time-saver on those. Thank you.
