how to remove square brackets and text between them from the end of file or folder name?
for example:
c:\folder_name [useless text]
to
c:\folder_name
couldnt expect such turn , thanks a lot !
@zodna In case that is a problem, you should note that if there is something in the name after the brackets, that rename pattern will also kill it, e.g.
Keep [Keep] Tail
becomes
Keep
Here is a regex preset that preserves file names with a "tail" after the brackets:
Btw in the Old Name field, the initial "|" is the cursor (captured by the screenshot), it's not in the regex.
[quote="playful"]@zodna In case that is a problem, you should note that if there is something in the name after the brackets, that rename pattern will also kill it, e.g.
Keep [Keep] Tail
becomes
Keep[/quote]
I think you've found a bug in the beta.
Oh, great!
